Having transmission problems need help!!!
I have a 1986 chevy c1500 silverado and I have two problems i am having trouble with and would like to ask for advice. My 350 turbo is leaking transmissioin fluid towards the front of the tranny closet to the motor and was wondering what it might be. Also my vents are not working. all of my air goes to the floor vent, nothing else works. if anyone can help i would appreciate it.
front pump seal is why your tranny is leaking.....make sure when you get it changed you get it "staked" so it doesnt push out agian.....as far as vents go if I remember right the 86 was cable controled....pull out the control panel and check it out you may have a broken cable or airflow control door
