croaker |
08-17-2010 08:57 PM |
Answer myself
For anyone else that is looking at this job. Two quick connect nipples at the firewall one black one White. White one is ten bucks more then the Black guess which one is broken? So says special tool required for removal. Anyways the quick way seems to be cutting it off combination dremel and hacksaw blade real tight quarters care should be taken not to cut the core inlet tube. A O-Ring is also required. Replacing the core by the book requires discharging and removing A/C box and dash removal and looks like cutting these connects for removal. If the core craps out it I think it will be someone elses problem
