help!
need to run a sub power wire! can find a hole to run it through.. anyone know where to run it!
I ran mine from the battery then down to the bottom of the firewall and under on driver side, there is a grommet with wiring running through it on floor pan. Take the driver side floor trimming off and pull up carpet. I pulled through there and ran to back. Under I zip tied it to the brake lines.
I ran mine through a rubber boot on the drivers side firewall. It has a few wires going through it, but has alot of rubber grommet to run through (like 2 inches all the way around). I just took an awl and made a hole and ran it through there. It is away from the metal edge and was easy to run through.
i used ruffnecks way lets see how it works... i need to finish tomorrow stupid rain! but the rubber boot was sooooo hard to get anything through
