Help! Inside cab noise driving me crazy.
Old May 10, 2010 | 03:42 PM
sutehk's Avatar
Default Help! Inside cab noise driving me crazy.
Hey guys, new to the forum, and have been reading alot. Learned alot. I recently picked up an 04 Silverado 25000HD. Inside the cab above the driver's seat there is a tweeter speaker looking circular grill. When I start my truck, this noise like a small fan hitting someting starts also. It will continue until I shut the truck off.
What is this thing? Any ideas on what is going on?
Thanks
Chris
P.S. This sound is coming from the tweeter looking thing. If I place my hand over it the sound softens.
Last edited by sutehk; May 10, 2010 at 03:44 PM. Reason: forgot to mention where the sound is coming from
Old May 10, 2010 | 05:16 PM
Removed wrong information.
Old May 10, 2010 | 05:18 PM
acnas's Avatar
If you have the automatic temp system it is the inside air temp sensor. There is a fan inside it, which is making noise. Parts dept call it a aspirator. If you replace it it comes out from between the headliner and roof. The grill holds it in place to the headliner.
Old May 10, 2010 | 05:26 PM
sutehk's Avatar
Is this an easy part to replace? What is the process to replace this fan? Any ideas on the the cost of the part? Yes, I have the automatic climate control. Thanks for the help fellas, this has been driving me nuts ever since I got the truck.
Chris
Old May 10, 2010 | 07:55 PM
acnas's Avatar
INSIDE AIR TEMPERATURE SENSOR ASSEMBLY REPLACEMENT
REMOVAL PROCEDURE
1. Remove the left windshield garnish molding.
2. Remove the left center pillar assist handle.
3. Remove the left center pillar garnish molding.
4. Remove the left sunshade.
5. Gently pull down the headliner.
6. Disconnect the electrical connector from the inside air temperature sensor.
7. Partially remove the inside air temperature sensor from the headliner.
8. Remove the sensor grille from the inside air temperature sensor.
9. Remove the inside air temperature sensor from the headliner.
Not sure of the cost of the sensor.
Old May 11, 2010 | 08:45 AM
sutehk's Avatar
Thank you acnas. I will look/call around for the part and go from there. Thanks again for your help. I really appreciate it.
Chris
Old May 19, 2010 | 10:04 AM
sutehk's Avatar
I finally got around to putting that part in acnas. Was even easier than your intructions sounded. Again, I thank you for helping me out.
Cost of part from the local GM dealer: ~ $40
Cost of aftermarket part: ~ $25 - $35 (didn't want to wait for shipping)
Time: ~ 20 - 30 minutes
Piece of cake, and no more buzzing in my ear.
Chris
P.S. I included all the details for other people who may have this problem.
Old May 19, 2010 | 10:50 AM
acnas's Avatar
No problem.
MRC Chevy
Apr 11, 2015 02:03 PM
Travis West
Jun 15, 2011 06:25 PM
GMCSierraFan
10
May 29, 2011 11:14 PM
purginss
11
Apr 7, 2010 08:16 AM
sethj
Aug 4, 2008 04:12 PM
