help me decipher RPO codes
Old Jul 18, 2011 | 01:40 PM
  #11
Yes - pull the cluster and make sure the little motor in there is plugged in and nothing is jammed.
Old Jul 18, 2011 | 03:47 PM
  #12
Razoo's Avatar
Originally Posted by NullHead
My dad said he tried to find how full the tank was one day, and put $90 into the tank and she was still taking it, so he got sick to his stomach and called it quits. I imagine it's a 25 gallon tank though.
Usually long beds get 35 gallon tanks. I know that true for the 99 and newer trucks. Don't see why it wouldn't be so on the previous body style.
Extended cab trucks get 25 gallon tanks, though. I suppose it has something to do with not letting the tank continue under the cab.
Old Jul 18, 2011 | 06:24 PM
  #13
cubpak89's Avatar
my dads 99 suburban has a 44 gallon rear mounted tank where the spare tire would normaly be on a truck
Old Jul 18, 2011 | 09:36 PM
  #14
NullHead's Avatar
On a semi-related note, what wound be involved with stiffening up my differential for snowy conditions? This thing is less than perfect from what I understand. Is it possible to put thicker fluid in the rear end to help with that? I was hoping to change out the original factory fluid in it anyways. Suggestions?
Would something such as this fit in my current axle, or would I need to swap the whole thing ..
Old Jul 18, 2011 | 09:50 PM
  #15
MrDragon's Avatar
Thicker will also mean hotter, causing more wear on parts and possible failure. It's usually best to stick with recommended fluids. Unless there's a spec recommendation for harsh environments
Old Jul 19, 2011 | 01:49 PM
  #16
Razoo's Avatar
Yeah, My old Burb had a 44 gallon tank, too. I absolutely loved it. These wimpy little 25 gallon tanks they're putting on short beds and crew cabs just suck, in my opinion. Like I said, 2 of my vehicles have 35 gallon tanks, and the 2008 has a 25 gallon tank. I'd like to see if there is an upgrade, or aftermarket 35 gallon (or larger) tank.
In2Trux
Apr 13, 2014 09:35 PM
mozongo
Jan 20, 2012 05:23 AM
NovaSS
Aug 1, 2009 09:41 AM
dmccartyfan
17
Feb 4, 2009 08:12 PM
robertbassin5
Aug 20, 2008 10:22 PM
