-   -   Homemade Cold Air Intake (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/homemade-cold-air-intake-10773/)
Mr_Shamrock Jul 26, 2009 02:21 PM
OK I know somewhere I have seen some homemade CAI's, but I can't seem to find them now. I want to add one to my truck, but just can't see paying $200 plus. Do any if you have any pics or ideas to make one? If so, what kind of gains have you seen? Thanks in advance!
RUFFNECK4LYFE Jul 26, 2009 03:16 PM
1 Attachment(s)
Autozone has one off the shelf for 149.00!! They stock it now for the 99-06 GM motors. I put it on mine and I could tell a big difference. Of course I already have the tune and cam for it.
Mr_Shamrock Jul 26, 2009 03:18 PM
And it came with the filter too? Do you have a part number?
RUFFNECK4LYFE Jul 26, 2009 03:36 PM
I found it cheaper here friend!!! For 105.00!! Scroll down to GM...http://www.jegs.com/p/Spectre/Spectr...58133/10002/-1
It does come with a filter, heat shield, and intake tube, clamps, rubber boots, everything you need...http://www.jegs.com/i/Spectre/865/9900/10002/-1
Mr_Shamrock Jul 26, 2009 07:10 PM
Nice find man! Before I order it were you very happy with it. Was there anything that was suspect or cheaply made?
RUFFNECK4LYFE Jul 27, 2009 12:29 PM
Na I love it! Made quite a difference in throttle response and torque. The material is pretty durable. I've used their cone filters before with no problems. Heck you could even get a K&N cone filter and use that instead. The intake tube is very clean and large. Its 4 inches in diameter. Im probably gonna get it ceramic coated here where I work to block hot temps. Here it is usually 100 degrees out. The intake temp reads around 110 at a stop and will drop down to 85 on the run. I have electric fans. So well worth it.
timber74wolf Jul 28, 2009 02:35 PM
If you insist on runnning an open air filter such as the spector of K&N cone filter get a dry charger or another name for it is a "pre charger filter wrap" to cover it. All it is is a tightly woven nylon mesh that goes over the open filter with elastic on either end. It will keep the water of the cotton or paper filter and keep the filter cleaner longer. I ran just my K&N CAI and the filter had a white spot on it after 3 months... the oil had disappated off the cotton due to the rain and other nasties that were blowing on it. The dry charger/ filter wrap has stoped the water and the filter is clean still even after 2 years since I installed it. http://www.summitracing.com/search/?...%20wraps&dds=1
RUFFNECK4LYFE Jul 28, 2009 03:07 PM
Thats a good idea!! Thanx friend!
Mr_Shamrock Jul 28, 2009 06:29 PM
Thanks for the info...there is a seller on eBay selling CAI's for under $60 plus shipping. Let me know what you guys think...
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
I went to Autozone to check out the Spectre kit and it looks real decent. I just wonder how long before that shiney tube starts to rust. Are you having any sign of that ruffneck? Also what cam are you running?
