Horn problem.....
Old May 3, 2008 | 03:50 PM
jcbst12's Avatar
Default Horn problem.....
My horn works when it wants to, which is rarely. I am assuming it is the relay. Any idea where I can find it on my truck?
Old May 3, 2008 | 05:06 PM
Argon's Avatar
Default RE: Horn problem.....
its underhood in the fusebox...but i ain't seen a bad one in years
Old May 3, 2008 | 06:08 PM
jcbst12's Avatar
What else would cause an intermittent horn? I'd say once out of every 5 times I use it, it works. It works with the key FOB always. I tried cleaning the contact in the steering wheel but I don't like doing that cause of the airbag.
Old May 3, 2008 | 06:18 PM
Argon's Avatar
well,the relay is good if the fob works the horn...its most likely the wire that goes into the contact loose,due to a broken contact...thats the most popular
[IMG]local://upfiles/3541/18E728376C694D21ADA9120482EC1DF8.gif[/IMG]
Old May 3, 2008 | 09:25 PM
jcbst12's Avatar
I think you are right. I was just messing with it. If I hit the centerpiece low instead of in the middle, it actually works. I did this like 10 times and it worked consistantly. (F*** the neighbors, lol) Is it worth tearing apart you think?
Thanks a lot argon!
Old May 4, 2008 | 05:53 AM
Argon's Avatar
its a cheap part...maybe 8 bucks for a contact...but yes,AIRBAG SAFETY..also,you'll need a lockplate depresser to get the contact off
Old May 4, 2008 | 05:54 AM
Argon's Avatar
it COULD BE the horn pad itself as well..only 1 way to find out
Old May 4, 2008 | 07:43 PM
jcbst12's Avatar
Ok thank you Argon. I'll let you know how it turns out.
BLK02
Jul 30, 2010 03:52 PM
Bowhunter4lfe
May 4, 2010 04:18 PM
isaac_22
Dec 24, 2007 12:33 PM
fordster
Jan 5, 2006 09:09 PM
outdoorxman
Aug 1, 2005 03:17 AM
