RE: How long to keep supercharger
Tayoz....I have all three pulleys and they work great in all weather and all altitudes. Small pulley good for the hotter more high end power.
Torque converter but if youre running with a stock cam you probably dont have one. Do you have any supporting mods to youre truck? or did you buy it like that. If so you might have even more than you think.
The size pulley determines how much boost youre running. In most superchargers you can only run as much boost as youre spring in youre waste gate will allow.
ORIGINAL: markbark RX Steven...you will be the first to know!!. Well its a whipple 6 lb twin screw. I have the air raid cold air intake as well as the elongated pistons allowing for more air flow into engine. What do you think 72 charger? what is the body of your truck (ext cab sb)? whats your 0-60? |
