idea's on easy wat remove chrome fender trim
the screws won't budge, any tips or idea's?
1/8"drillbit and drill out the screws. Otherwise you'll be doing a lot of screaming at old stuck screws.
yea drill em out and the fender flares will leave a black residue on the paint. wash scrub an buff off if needed.
Next?? any more ideas, first screw broke the only bit i had an i had borrow it an drill from work, an trust i'm cussing screws an the ahole that thought putin phillips head screws in that to start with.
I usually take a dremel and cut a slot in them and then use a flat screwdriver if i can't get vice grips to grab them.
Or if you're careful with the dremel you can cut the head off the screw.
| All times are GMT -5. The time now is 06:09 AM. |
