Idler Arm replacement
2 Attachment(s)
1991 C2500 Silverado Ext cab
I bought this truck new and now I'm doing some maintenance on the steering components, after all these years. I'm replacing the OEM idler arm, but having difficulty finding what I consider to be the correct one. The OEM idler arm is actually a two piece unit. the arm itself screws into the frame bracket, something I have never seen before. I have tried to find this idler arm through several sources, but so far, nobody has one like it. Anyone else out there ever had this type of Idler Arm and if you replaced it, what did you replace it with?Attachment 1632 Attachment 1633 |
