Instaling after market CD player
Hey guys
I am currently trying to wire in a New CD player. I am uncertain as to which wires are for power, and which are for the speakers. I pulled the stock radio apart and found that the wires are all welded to the computer chip inside, so i don't believe i can get an adapter for it If anyone happens to have a wire diagram could they please post it. Any help at all would be welcomed Also, there didn't seem to be enough wires for 4 speakers with ground and power wires, so are the speakers ground to the frame where they're mounted? thanks again :confused: |
Crutchfield is your friend! There most certainly is an adapter between aftermarket head unit and your truck. Check out Crutchfield.com, or give them a call. Their customer service is superb.
Year and model?
year and make
the truck is a 1990 chevy scottsdale
Red is 12+. Black is -. Yellow or orange is constant 12+. Speaker wires are probably white, gray, purple, green. Those are the main ones. The yellow or orange from the deck needs to go to constant 12+ to keep memory.
listen to what they first guy said go to crutch field buy the adapter its about $20 all the wires are color coded its idiot proof just get some blue wire crimpers and crimp the wires together wrap in electrical tape just to be safe it will take like 10 min
If you read his question again, he said he DOES NOT think he will need an adapter. He is just wanting to know which wires are what.
CD player
hey guys, I checked out the crutchfield web site, and they didn't have an addapter for a silverado or scottsdale.\
I went and pulled off the wireing harnesses from the radio and Casset player The radio wire colors are: white Orange Red Yellow Brown Black The Casset player wire colors are: Blue/Black Black Grey Black Orange Black,Red, and white wrapped in a black cover Brown If anyone can tell me what wire is what each of these wires does it would be very helpful and very much appreciated I did go to Canadian tire and picked up a E2 adapter for 88-05 GM/chevy, but it doesn't match up with what my truck has |
bypass
ok, i decided to say screw it and just bypass the plugs, so i just ran wires to my fuse box for power, but i'm not not sure where to find the speaker wires, if anyone could help with that, and also with the colors, the wire colors are listed above
