Installing neon on the interior of an 01 silverado
What do you have to do and what all is required to install it. I have the neons and an on/off switch..do i need nething else? where do i need to mount the switch and run the wires? I need to know all of the details....thanks
RE: Installing neon on the interior of an 01 silverado
First decide where to mount the Neons, if they’re hard tubular, you may want to consider mounting them under the seats/dash so they’re not too bright at night.
Next, decide if there needs to be an inline fuse/resistor (if these were designed for automotive use ignore this step) Find a power wire (ignition on or constant power) from under the dash or hood to run your power). Measure the amount of wire you will need Run the appropriate gauge wire (usually 16-14awg) to the switch, from the switch to the Neons and the neons to a ground. Install the switch, secure the neons, and make sure all your electrical work is well insulated. . . Test and admire your work |
