Intake Mod 2
Old Jul 27, 2007 | 08:45 AM
wannarex's Avatar
Default Intake Mod 2
I was going to ask this in jcbst12's thread, but decided to start a new one.
The question is....Has anyone cut off the silencer box from their stock intake? I mean the box that is between the MAF and TB. I have read on other forums, about other vehicles,about deleting that piece and putting a cap over the place where you cut it off to re-seal the intake.
It seems to me that would make a slightly smoother air flow.
Old Jul 27, 2007 | 09:13 AM
jcbst12's Avatar
Default RE: Intake Mod 2
It would produce slightly less turbulence to the air going into the throttle body, but I don't know if it would produce noticable gains.
Old Jul 27, 2007 | 11:59 AM
wannarex's Avatar
Upon closer inspection, I don't think this is possible. There doesn't look like a good way to re-seal the intake tube. I was trying to not spend the money for an AIRAID MIT or K&N intake. The airraid is like $110. For a 16" piece of plastic tube?? WTF??
I guess, ya gotta pay to play.
Old Jul 27, 2007 | 01:03 PM
stopspazinout's Avatar
thats nothing compared tyo a 300$ piece of plastic from k&n
Old Jul 27, 2007 | 03:39 PM
popo's Avatar
jsut put the top of a spray paint can in it thats what i did and it sealed perfectly. if you want to get fancy and put the box back on for looks you can seal it with a cut piece of metal and reinstall it.
Old Jul 28, 2007 | 01:27 PM
wannarex's Avatar
ORIGINAL: stopspazinout
Yeah, I was thinking $110 AIRAID, minimum.
And popo, I don't know if our intakes are different but that "silencer box" (is that correct?) is formed into the intake by a kindof teardrop shaped chamber. At first I thought it was round with a fin on it, but now I'm pretty sure I couldn't just cap it with something round.
Old Jul 30, 2007 | 05:24 PM
chevy112488's Avatar
im pretty sure i paid less than that for my mit from summit racing...
Old Jul 30, 2007 | 06:25 PM
thomas's Avatar
mine had a small flap in the entrance to the intake by the filter, so i just took it out and used a rivet gun to hold a small 1/4 in. thick aluminum plate on. nothing noticable but its whatever works. my truck also had the option for a dual intake (im guessing for an 87 diesel?) so i bought another intake and wa-la. dual intake for $10. the intake tubes are right behind the grille. even airaid and k&n cant do that
Old Jul 30, 2007 | 09:29 PM
Cracker's Avatar
The first silencer, between the block and wheel well can be significantly shortened by cutting it off 1/2 to 3/4" from the main and capping it with a Fernco rubber pipe cap available from you local home improvement store.
Old Jul 31, 2007 | 09:01 AM
wannarex's Avatar
ORIGINAL: Cracker
That is exactly what I was planning, but mine is such an odd shape, I don't see a good way to re-seal it.
I think I saw an Airaid mit in Summit fro $110 for my application.
