-   -   interior lights/cargo light not working (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/interior-lights-cargo-light-not-working-6477/)
chevy112488 Mar 6, 2008 01:45 PM
i was driving yesterday and i (tried to) turned my dome light on, and my cargo light on message came up. the dome light didn't come one, and the cargo light wasn't on. after some messing around, this is what's happening:
when i turn on the dome light, overhead map lights, or cargo light, the cargo light message appears, but no lights come on. none of my lights inside work except the gauges.
both interior light fuses are good.
any ideas what the problem might be?
knoxy Mar 6, 2008 02:30 PM
RE: interior lights/cargo light not working
is it possibly the dome override switch? i dont know but i thought it might be worth a shot. often the simplest solution is the right one
chevy112488 Mar 6, 2008 02:34 PM
no, i tried messing with that, that's what i thought at first too, since i press it a lot to turn the headlights off
knoxy Mar 6, 2008 03:51 PM
then i think this might be a question for argon. i would see if you can follow the wiring diagram and see if there are any loose connections in the vehicle. you said that all the fuses are good, then it has to be wiring somewhere. just follow the diagram, i believe there is one in the manual but if not there is one on the net for sure!
good luck!
Argon Mar 7, 2008 04:00 AM
no dash lights either?...how about tail lights?...
chevy112488 Mar 7, 2008 12:10 PM
dash lights and tail lights both work... the only lights not working are cargo, dome, overhead, the ones in the doors, and the ones under the dash
Argon Mar 7, 2008 01:10 PM
dude..just a guess...but i'd say your switch is bad...assuming all fuses are good..the bcm COULD be the culprit,but thats a long shot
chevy112488 Mar 7, 2008 02:09 PM
is that something i can check and/or fix myself?
Argon Mar 7, 2008 03:20 PM
looking at the schematic...make sure the courtesy fuse underhood is good AND has power thru it...
after that...its either try parts or get it checked out....we need to see if there are any codes in the body pooter...(bcm)
chevy112488 Mar 9, 2008 10:35 AM
well, the fuse was blown, but a new fuse didn't fix it... how can i check if it has power through it? and can o'reilly or autozone check the bcm or do i need to take it to a dealer?
