intermitant starting problem
After warm up, at times, my 1998 Silverado, 5.7, ½ ton, 2 wheel drive, will turn over and briefly start then die. It continues to do that unless you let it sit for about an hour then it starts and runs. The fuel pump is working. When you turn off the key it does its usual run till pressure builds then shuts off. It has not shut off after it does start, only after you shut it down and try to restart. It seems to me that it is losing ignition rather than fuel. Could my issue be with the security system? Thanks for any help you can give!
sounds like a possible control module issue
As in what control module? The main ECU? Thanks!
ignition control module should be located under the distributor cap sounds like its getting hot and shutting down
Thanks!! I'll check it out!!
or bolted to the side of the distributor.....I forgot I havent looked in a while
Thanks! I'll check it out when I get off work!!
It ended up being the ign. switch not sending a signal to the security system. $510.00!!!! OWWWWW!
Yeah I was gonna say ignition switch. You coulda saved some money...http://cgi.ebay.com/ebaymotors/1999-...Q5fAccessories
Not a bad deal! The $510.00 I put out did include labor! The switch though was about $240.00!! Oh well, you snooze you lose!!!!!!!!!!!!!
