-   -   key cylinder remover (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/key-cylinder-remover-6368/)
ob22005 Feb 28, 2008 03:05 AM
what's the procedure of removing the key cylinder from a c1500 gmc truck. can anyone tell me.
Argon Feb 28, 2008 07:25 AM
RE: key cylinder remover
what year?
ob22005 Mar 3, 2008 02:34 PM
Sorry About That. It's A 1989
Argon Mar 3, 2008 02:59 PM
89isprettysmple,but you'll need a couple of special tools....a steering wheel puller,and lock-ring depressor...the key cylinder is pretty cheap with 2 new keys...
ob22005 Mar 3, 2008 05:02 PM
I've removed everything down to cylinder but it won't come out, the key is stuck in the run position.
Argon Mar 3, 2008 05:19 PM
did ya take that torx bolt out???
ob22005 Mar 3, 2008 08:40 PM
Didn't Know About A Torx Screw. Where Is It Located??
ob22005 Mar 3, 2008 08:46 PM
There Is a Bolt Just Above The Cylinder, Not A Torx, And It Just Turn But Won't Come Out.
Argon Mar 4, 2008 03:22 AM
yeah..under the turn signal switch...then there is a plastic/metal key buzzer spring to take out of a hole...then it should be a torx...unless someone switched it
