-   -   Key fob and lock not working (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/key-fob-lock-not-working-4661/)
hunt4game29 Oct 1, 2007 04:03 PM
I have a friend with a 2003 chevy tahoe LT and both key fobs stoped working and when you press the lock bottom on driver side on the door it does not lock the passenger side but locks other three doors. We have tried to reprogram the key fobs but nothing. So we dont have a clue what it could be. Thanks guys.
quick02 Oct 1, 2007 04:15 PM
RE: Key fob and lock not working
Many locksmith shops now, are able to fix that. They have a wide selection of factory remotes etc..... It'd be worth a shot.
jcbst12 Oct 1, 2007 05:32 PM
Does the door lock/unlock with the button on the door?
hunt4game29 Oct 1, 2007 06:01 PM
No the door unlock lock botton on the door does nothing.
SouthBayZ71 Oct 1, 2007 06:36 PM
This happened on my wifes van 2 years back ...but it's a Dudge ...I had to replace a relay.
Argon Oct 2, 2007 05:41 AM
A blown lighter fuse will stop the door locks from working with the switch...the fobs are probably another problem
jcbst12 Oct 2, 2007 08:37 AM
Either fuse or maybe the actuator(?) to unlock that paticular door went bad.
smoke20 Oct 2, 2007 05:59 PM
Hunt - does the window work on the passenger side? If not, may be a bad connection. Maybe at the door switch itself.
hunt4game29 Oct 4, 2007 01:16 PM
Okay guys the window on the passenger side does not work. So what should we check? Thanks
Argon Oct 4, 2007 02:25 PM
only 1 way to be sure...remove the panel and check it with a test lite...it works from neither switch,I assume/
