knock sensor trouble
Hi all this is my first post on here will see how this goes I have a 2005 silverado Z71 5.3 v8. I recently had a check eng light pop on took it to my local Auto zone to get a reading.test results state that the 2nd bay #2 knock sensor has low output does this mean its working and about to go out? Or is it gone out completely? or maybe a harness problem? either way i am going to replace just curious. My 2nd question would be is there a knock sensor on either side of the block or side by side. cause in a diagram they had on the computer at Auto zone showed them side by side is this true cause i would think they are on opposite sides.
My next question would be when i do go to replace it what all is involved in doing so? thanks for all who post Keep on truckin lifted4christ2005 :) |
First off welcome to the forum........as far as the sensors being side by side I dont think so I would say one on each side and should be pretty straight forward as far as how they come out
so what side is sensor #2 then >? pass / driver?
also do i have to take apart the intake manifold to get to it? |
They are under the intake and side by side. Intake needs to come off to replace. All the ones I have changed are corroded from water. Do yourself a favor and buy 2 sensors and the harness when you repair this. Torque is critical on the sensors. I usually rtv the front half of the rubber caps to the block so water can go around the plugs and not into the sensor. You also need intake gaskets. Not a hard job. Good luck.
Originally Posted by acnas
(Post 58555)
Once you take off the sensors you will tell for sure which is bad. They will be so corroded and rusted. Use high temp silicone and use it like your brother sells it!! Once this is done, you will notice a power increase. Good luck!
Hey thanks again everyone for your input been a big help. Just 1 more ? When taking off the intake manifold can I get to it from the top or bottom or am I going to have to pull the inside wheelwell off?
Make sure your not confusing the intake manifold with the exhaust manifold. The intake is right on top of the motor. Everything will be done from right on top.
This will give you better idea I think...
Awesome Bro thanks for the Help video was great.. Yeah i was thinking exhaust manifold thanks again im going to tackle this it weekend looks
| All times are GMT -5. The time now is 06:12 AM. |
