-   -   knock sensor trouble (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/knock-sensor-trouble-14216/)
Lifted4Christ2005 Jul 26, 2010 12:06 AM
Just an update got everything cleaned up and all put back together everything seems to running great if not better. Thanks again all you have been a big help.
Lifted4Christ2005 Jul 26, 2010 12:07 AM
oh ya no more check engine light <br>
RUFFNECK4LYFE Jul 26, 2010 10:03 AM
Alright good deal!!
Mr_Shamrock Jul 26, 2010 10:54 AM
Sweet! Glad we could help!
reyfield Aug 1, 2010 12:19 AM
i have a 2004 silverado with a 332 code. you will probally find the rear sensor totally rusted and the front in mint condition. it will be best to replace both sensors and the wiring harness. make sure you use only o.e.m. parts not aftermarket. trust me aftermarket parts will not signal correct to your computer. i learned this the hard way. clean the rust completely out of the sensor cavity. if the rubber bottom in the cavity is lost due to cleaning. replace it by squirting in some blue rtv sealant and run around the bottom with your finger.also do not overtighten the knock senser. hand tight and then one quarter turn with rachet. good luck
Lifted4Christ2005 Aug 1, 2010 07:52 PM
thanks for the infoI already replaced the two sensors and the harness and yes i did use aftermarket parts for far no trouble seems to be working great i wish i knew how to post pictures on here i would show all my pics thank for the input thought
https://www.truckforums.com/forum/im...tons/quote.gif
acnas Aug 2, 2010 08:55 PM
Tighten the sensor to 20 N·m (15 lb ft).
