-   -   leak at water pump (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/leak-water-pump-5415/)
deadwood144 Dec 6, 2007 07:58 PM
leak at water pump
I have a '03 stepside, 4.8L (64k miles) that's losing coolant. There is some discoloration where the water pump meets the engine block. Any guidance here about where to start? Thanks.
[align=left] [/align]
Cracker Dec 6, 2007 08:01 PM
RE: leak at water pump
The weep holes are warning signs that your pump is failing, and also causing the discoloration. Change the water pump and the T-stat at the same time.
smoke20 Dec 6, 2007 08:02 PM
Once again cracker is right, pump time.
Cracker Dec 6, 2007 08:03 PM
Hah...who says alcohol clouds your judgement.
deadwood144 Dec 6, 2007 08:10 PM
Smoke/Cracker,
Are these weep holes/ indicaters at the area where the pump mounts to the engine? Sorry to be a blockhead, but failues of water pumps on past trucks were different.
racethisz71 Dec 6, 2007 08:14 PM
mine was leaking from the constant tension clamp that connects the raditor hose to the waterpump
Cracker Dec 6, 2007 08:22 PM
The weep hole is below the line of sight when looking at the top of the engine. I assumed your view was from that vantage. The coolant will follow the "arms" of the pump to the block and leave a residue of rust and debris that naturally occures in the coolant system.
deadwood144 Dec 6, 2007 08:43 PM
Thanks for your help. Should the timing belt be changed at this point while the pump is off?
smoke20 Dec 6, 2007 10:10 PM
Only if there is an issue. How many miles on yours?
Argon Dec 7, 2007 04:32 AM
Timing belt?..i'm not even as drunk as cracker tonite,and I know there is no timing belt...just a drive belt....
price a gm pump...comes with a thermostat as well,and you won't have to change it again next month
