Leaking water
Old Oct 11, 2010 | 10:23 AM
80skeys's Avatar
Member
Default Leaking water
When use the air conditioner in my '91 Silverado, some water drips from beneath the glove compartment.
Anyone know what I need to do to troubleshoot and fix this?
Old Oct 11, 2010 | 10:43 AM
RUFFNECK4LYFE's Avatar
There is a drain tube on the firewall inside the engine bay on the passenger side. Raise up the vehicle and get underneath to find this tube. Its bout 3/8" and will tend to clog up like rain gutters. Stick a wire in there to break up the clog. Some even use air to blow it out. This is very common and you may need to do this at least once a year.
Old Oct 12, 2010 | 01:12 PM
80skeys's Avatar
Member
Is it really necessary to raise the truck to get to the drain tube? Where on the firewall is this tube located? I popped the hood and looked around the accumulator but could not see it.
Old Oct 12, 2010 | 09:35 PM
You can only access it from the bottom. If you can fit under without jacking then try it. Its gonna like if its directly behind the glove compartment.
Old Nov 1, 2010 | 10:47 AM
80skeys's Avatar
Member
Is it right next to radiator coolant lines that come out of the firewall? There's an opening there (no tube though) and it's the only opening I can see that might fit the description.
Does the opening face the front of the vehicle, or does it open downwards underneath the glove compartment?
Old Nov 1, 2010 | 11:44 AM
Thats probably it. Thats how it is on my 99 Tahoe. I pushed a rod through there.
In2Trux
Apr 19, 2015 08:50 PM
FLARAIDER
May 10, 2011 04:17 PM
biker3777
Nov 18, 2008 10:44 AM
BirdDooHead
Sep 8, 2008 05:32 PM
unit731
Jul 23, 2007 11:48 AM
