-   -   Lift kit silverado 2500 (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/lift-kit-silverado-2500-a-4118/)
Booonie Aug 13, 2007 10:27 AM
Helloo
Where can i find body lift kit to my silverado Chevy2500 6,2D 4x4 -90?
how big tires can i have on the truck without lift kit?
gpet6669 Aug 13, 2007 10:48 AM
RE: Lift kit silverado 2500
What year?
BlackHorse99 Aug 13, 2007 11:27 AM
ebay, you can probably get around a 31 in there, 33s with the lift?
Booonie Aug 13, 2007 03:50 PM
ORIGINAL: gpet6669
What year?
1990
every kit i have found don´t fit diesel
gpet6669 Aug 13, 2007 04:32 PM
You should be able to tuck 35x12.50 under it with only minor rubbing if you don't want to trim. other than that, I know that J.C. Whitney has body lifts for pretty cheap. Take into account that you will need to extend your brake lines and possibly your stearing shaft. But the brake lineswill have to be done on any lift. The suspension lift you will have to get it aligned and see what you will need from there. If I remember right you have IFS right?
Booonie Aug 13, 2007 04:47 PM
ORIGINAL: gpet6669
thanx
Ifs whats that?
gpet6669 Aug 13, 2007 04:56 PM
Independant Front Suspension (IFS)
Booonie Aug 13, 2007 05:07 PM
ORIGINAL: gpet6669
okay
yes it is
gpet6669 Aug 13, 2007 05:09 PM
Then for the front end, if you do a susp lift, you will need to get it aligned. If you do a body lift then you will keep the same geometry in the front so it wont matter!
Booonie Aug 29, 2007 02:16 PM
J.C. Whitney don´t sell body lift to disel silverado:(
where can i find body lift kits?
