-   -   Loud squeel when fan or AC turned on (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/loud-squeel-when-fan-ac-turned-17658/)
Wile e.1. Oct 4, 2011 05:08 PM
Have an 02 Sierra 5.3 Z71, 30 k miles. When I put the air or heat on , there is a couple second loud sqeel under the hood, goes away then does it again. After a few times it happens less and less and will go away while driving. I changed out the serpentine belt ( the original ) no change. I guess it is a pully or bearing ??? Anyone have experience with this, Oh yeah...sometimes happens when starting. Very annoying, but as you can see , the truck is not driven too often. Any help appreciated. Thank you
acnas Oct 4, 2011 06:17 PM
Did you change the main belt or the ac belt? Possible ac belt and or ac belt tensioner? Seen the ac belt tensioner seize.
Wile e.1. Oct 4, 2011 07:29 PM
I changed the serpentine belt, and the tensioner seems ok...tension is good, spins fine. ( is there 2 belts on a 02 sierra, thought there was only 1 main belt ) Both the AC and the heat work well, its just the initial squeel from under the hood when the fan motor is turned on, I did not think the belt would fix it...its more of a metal on metal noise than a belt squeel. kinda like a bad bearing ..the noise will come and go for lets say about 15 minutes of driving ,only for short durations, then I wont hear it anymore till the next trip
Mr_Shamrock Oct 4, 2011 07:49 PM
Yes there are 2 belts - change the A/C belt.
Wile e.1. Oct 5, 2011 11:40 AM
thanks for the replys, found a u tube video for changing the ac tensioner and belt, so looks like I got a saturday project. Thankfully not a pricey or difficult lookin job. thanks again for your time
Wile e.1. Oct 5, 2011 06:02 PM
turned out to be the a/c tensioner, replaced it and put on a new belt also, truck sounds great again. thanks for the info.
Mr_Shamrock Oct 5, 2011 09:28 PM
Cool glad you got it fixed and thanks for posting your results!
