LOW+FOG, and HI+LOW+FOG, mod
8 Attachment(s)
New here and not sure if anyone has posted this exact mod here, but I've found this mod on another site and I'd thought I share it.
Here's what I did, it's still using the same diodes, just a different way of going about it. The pictures I'm showing are from Kenny C at FULLSIZEforums. Attachment 3355 Attachment 3356 Attachment 3357 Attachment 3358 Attachment 3359 Attachment 3360 Attachment 3361 Attachment 3362 Heres a layout of the connector, you put the diodes in from the top where the wire come in. Make sure to have the Diode going in the right direction. This will give you "Low + Fogs", and when in Hi, it will give you "Hi + Low + Fogs" (Make sure to use shrink tube on the diodes.) As I said above this is all from Kenny C, from FULLSIZEforums. I take no credit for this mod, just sharing it with others. I've done this mod and it works great. |
RE: LOW+FOG, and HI+LOW+FOG, mod
So with this mod are the fog lights always on when the low lights go on? Or does it just allow the fog lights and the low lights to stay on the the hi's are turned on. If you could let me know before I get started on this project I would appreciate it. Thanks.
| All times are GMT -5. The time now is 02:32 AM. |
