Lowering Kit (2007 Silverado)
Old Sep 10, 2007 | 07:44 PM
  #11
03missouridirt's Avatar
Default RE: Lowering Kit (2007 Silverado)
No problem...just post pics when you get it done. Their examples rocked.
If I didn't need the ground clearance occasionally I would lower my 4x4 like the SS is.
Old Sep 10, 2007 | 08:11 PM
  #12
Cleatus's Avatar
Will do. I can't wait....... lol Feel like a little kid waiting for Christmas....
Old Sep 11, 2007 | 02:07 PM
  #13
thomas's Avatar
im about to lower my truck when i take the bed off to paint. i was thinking about just moving the spring to the bottom of the axle and putting new u-bolts on. if its simple, why waste the money. or is it better to get a kit?
Old Sep 11, 2007 | 02:17 PM
  #14
chevy112488's Avatar
i read somewhere a while back (it may have been on here) that somebody did with the spring what you were talking about and they said it worked out fine... i wouldn't want to try it though, they put it on a certain side of the axle for a reason
Old Sep 11, 2007 | 02:22 PM
  #15
jcbst12's Avatar
Not really all that bad, people do it all the time. Im sure it could cause problems with the drivetrain if it isnt done right but I wouldn't worry that much. A co worker of mine has a 2000 2wd and that is what he did with the springs. Ride is bouncy but it works.
Old Sep 11, 2007 | 02:24 PM
  #16
ORIGINAL: thomas
You'll have to weld a new "pad/perch" on the underside of the axle housing. If you aren't familiar with what I'm talking about, you can look at the current setup on your truck... There is a pad that locates the spring onto the housing via an alignmentpin that runs through the springs. It will have to be moved/replaced with the springs. You also need to make sure that the pinion angle is correct when you lower it. All-in-all it isn't a hill for a climber...
Old Sep 12, 2007 | 09:34 AM
  #17
thomas's Avatar
yea ive looked at it. my dad has done it before, and a friend of mine did it to his toyota. the only thing is, is that it comes out to be about a 5 inch drop. i was thinking only 3 or 4 in the rear. drop spindles are the only RIGHT way to do the front end, right?
Old Sep 12, 2007 | 02:14 PM
  #18
From a safety and simplicity standpoint, I would say yes... Cutting coils changes their rating, leaves a nasty edge to deal with, and messes up your frontend geometry.
You could get re-arched springs for the rear and make it less of a drop....
With 5 inches drop out back, you'll need probably at least 3" drop up front to keep it level, andI would think they sell the D.S. in a 3"...
Old Sep 12, 2007 | 10:14 PM
  #19
thomas's Avatar
and prices on drop spindles? i know they are pretty expensive...
Old Sep 13, 2007 | 04:09 PM
  #20
Cleatus's Avatar
I ordered my 4/6 drop today. I can't wait......
