LS1 Truck?
Old May 18, 2004 | 04:55 AM
701NN's Avatar
Default LS1 Truck?
<FONT face="Verdana, Arial, Helvetica, sans-serif">Ok so we're talkin' at work and the subject comes up. Can the heads and cam from an LS1 Vette/Camaro go into my '01 5.3?</FONT></P>
If so, how tough to get the computer to be compatible?</P>
Old Jun 24, 2004 | 12:21 AM
Divergent's Avatar
Default LS1 Truck?
no, unless you have an LS1 in your truck already. You would likely have
to machine the heads to match your intake and probably more.
<edited><editID>Divergent</editID><editDate>38161.9321296296</editDate></edited>
Old Jun 24, 2004 | 03:22 AM
701NN's Avatar
Default LS1 Truck?
I hope you'll pardon my ignorance on this, but aren't both the LS1and the 5.3 considered to be GenIII engines? On the surface it would seem as if the heads, and intake,off the LS1 wouldinterchange.</P>
Old Aug 3, 2004 | 05:53 PM
gunnar@patriot's Avatar
Default LS1 Truck?
Actually, the heads and cam will swap right out. But you are better off with the 5.3 heads you already have. The LS1 heads carry a larger combustion chamber and therefore would lower your compression ratio. But you can still use the cam. <IMG src=smileys/smiley16.gif border="0">
Old Aug 3, 2004 | 06:11 PM
701NN's Avatar
Default LS1 Truck?
Not sure if my 1st reply came thru, but thanks for the info
Old Aug 3, 2004 | 06:56 PM
Default LS1 Truck?
No problem! Glad I could help.<IMG src=smileys/smiley20.gif border="0"></P>
korygrandy
19
Jul 17, 2015 09:00 PM
joshcaniglia
Sep 7, 2009 08:17 PM
BigRandy95
Feb 26, 2008 07:11 PM
MrLM7
Aug 13, 2007 10:08 AM
emmerich5.3
Jul 18, 2007 11:12 PM
