NullHead |
10-20-2016 08:49 PM |
Check for broken off bolts in your exhaust manifolds. If you have any broken ones, they're most likely on the back cylinders on each bank. Relatively easy fix, I always pick up bolts and new gaskets from the dealer. New design on the bolts, and the MLS style exhaust gaskets work really nice and are really heavy duty. I usually recommend you remove the exhaust manifolds, weld a nut to the remaining bolts that are still suck in the cylinder head, then turn them out with a wrench. Somewhat of an easy fix, but may not necessarily be easy to get the old broken bolts out of the cylinder heads.
