need a little help under the bed
Thank you for the add. Recently pulled the bed off for some needed frame repair (inspection would not pass). Took pictures of everything before disassembling for easy reassembly. Now i find out my phone account was hacked and lost EVERYTHING. up to and including cloud backup. Desperately need pictures of fuel lines from tank to evap system and wiring harness routing. I think i can figure it out but do not want to chance putting it back together and have it not run or worse yet the dreaded check engine light. if anyone has or can lead me to pictures of a 2004 Silverado with the bed off showing these it would be GREATLY appreciated. Could also use part numbers for the grey harness clamps (2 different sizes) i think i found them 1 is 10mm the other is 13mm is this correct?
