need specific guidance on my no heat problem
it's getting colder and I have little heat from the vents. the black box under the glove box is very hot.
can someone guide me to or post a picture of the actuator valve? Better get could someone post a schematic of what controls the fresh air door? I am getting tepid air from the vents after warm up. with the black box hot I am assuming the door is partially open and if closed I would get hotter air into the vent system. |
RE: need specific guidance on my no heat problem
This is what it looks like...the actuator.
http://www.dormanproducts.com/images...p1/604-100.jpg I haven't been able to find an "in vehicle" photo. |
I plan to take the glove box off this weekend to find this thing. is it in or onthe large black box that I can feel as very hot?
From the info I was able to find it is outside the box. There were hints to the location being behind the center console. I don't really have a direction to point you in for a search. I tried everything from "actuator" to "air blend door actuator, silverado" in a google search without much luck.
Auto Zone or Discount may have a diagram on thier in store computers. |
thanks for your help. I'll do just that.
heres what you got to do- lay on your back on the floor on the passenger side- in front of where the middle seat or console is at look right under the dash- now you see the pic they posted for you it looks exactly like that- i would check the conection to make sure its not lose- had the same prob the damn connector was lose- good luck
there are 4 of those...left and right temps...mode,and fresh-air....only 1 is fairly accessible
so is this something I may want to punt to the dealer?
you have no heat on BOTH sides?
when the truck has been driven and up to temperature there is a cool-warm feeling to the air coming from all vents. It appears to be equal throughout each vent.
