neep help wiring KCs.
Hey, im looking into getting a set of the KC daylighter 6" 100w lights which i will mount on the brush gaurd im getting. My question is, how and where do I power them. Im slightly familiar with wiring and electronics, but this is where i hit a snag. I know how to wire the lights, run the wires into to engine bay, run the switch, and ground them, but idk how I would go about powering them. Any help or suggestions would be great! thanks!
RE: neep help wiring KCs.
The lights should come with a relay and a fused power wire. The fused power wire can go directly to the battery or an accesory wire (depending on the setup). The relay will be spliced into your headlights so when you put your highbeams on the lights will kick on if the switch is on. Its pretty cool. Ground wire can usually be placed anywhere you can get a good ground. The wiring should go like this:
http://www.offroaders.com/images/pro...iring-diag.gif |
thanks a lot man! that is exactly what i needed, take it easy.
Welcome
