New/used 2005 Silverado questions
Just purchased a new/used 2005 2WD crew cab. This is my first Chevy truck. I Just have a few questions.
I got under the truck this weekend and noticed that there is a bar (bracket) attatched from the drivers side frame to the engine support crossover (sorry not technical). It looks like there should be another one of the same from the passenger frame to the support. There is not. Is this a critical issue ? Is this correct ? What is this bracket called (part number) so that I can get a replacement. I also have an issue with a bad exhaust rattlethat appears under load while drivingwhichgradually goes away as things heat up. It appears to be coming from the muffler area. Any ideas on this ? I have a third issue with the clunking in the steering column which I have identified using the posts from this forum. Thanks |
RE: New/used 2005 Silverado questions
You should pm Argon he's aGM teck
YEAH..2 BARS UNDER THERE....13MM BOLTS HOLD EM ON..not super-critical,but i'd get 1...its a skinny bar about 3 feet long,right?
the exhaust...its pretty much inpossibler for me to say not hearing it...if its a tinny rattle,look for the muffler...if its a rock-in-a-coffee-can sound,look for the cat/cats to be shelled inside....they have an 8/80 warranty on em the shaft...make SURE you get that part # that i posted...let me know if you can't find it,but it ends in 14...16193514,or something like that.its a new design and STOPS the problem...we sell em for 70 bucks..they list for 90.....we get 60 bucks to put em on...if you have tools and basic knowledge,you can put it on. |
The bar is 2 ft. 27 inches long. Pretty close to 3ft. for goverment work. Do you know what it is called and the number ?
Thanks for your response.... As far as the steering shaft I went out there after work and did what was recommened to temporarily fix the problem. I loosened and removed the 15 MM bolt and moved the shaft up and down for 20-24 times and replaced the bolt. I will check on this tomorrow morning to see it this worked. As far as the rattle, It varies with the rpms of the motor when cold and appears to be coming from the muffler. I guess this item will be a work in progress. Thanks again for the help.... ssp42 scott |
no clue on that bar part #..it can't be too high though..I imagine someone removed it to take the exhaust loose to replace the cats,and forgot to put it back
I get the same thing, a tiny rattle, but from the cat area. Any other way to tell what it is? Any other way to tell if it is the cats?
not really,no..just be under there listening...when a cat fails,it usually has a chunk/chunks of debris rattling in it
Ok, thanks. I should be ok then. Mine sounds like metal on metal rattle. Like a loose strap, sheild or bracket. Something like that. I just can't find it.
jcbst12,
That's exactly the way mine is. My truck has only 37,000 miles on it so I don't think it is the cats. Then again I could be wrong.. |
Get up under it and literally punch the pipes. Try to see where its coming from. I think mine might be these little washer things used on the O2 sensors. But I have no idea for sure. Its frustrating as hell to pin point thats all I know.
