No Fan on 1 & 2??
Old Aug 31, 2010 | 11:35 PM
alconk's Avatar
Member
Default No Fan on 1 & 2??
My 02 Silverado doesn't have any fan on speeds 1,2.. All the other speeds are fine. Could this be the HVAC unit itself??
Old Sep 1, 2010 | 12:15 AM
02camarossle's Avatar
Member
no its the risistor that is covered by the black cover underneath the dash, go to the parts store and get the a/c resistor it's like $30 should take about 10 min to install.
there are like 3-4 7mm bolts holding the cover on i believe and one is towards the middle of the truck and it's a bitch to get to, and then once you get that off another two bolt and it's the plug that has 5 or so wires going to it.
Old Sep 1, 2010 | 09:54 AM
alconk's Avatar
Member
Oh, I thought the resister was only for high speed??
Old Sep 1, 2010 | 12:20 PM
Member
no it's for all speeds i believe, my truck did that for a while, 1 and 2 didnt work only 3 4 and 5 replaced that and wamboozle it worked like new again.
Old Sep 11, 2010 | 12:18 AM
tareyton's Avatar
check your passenger air compartment filter if that clogs up it will cause the resistor to burn out faster. I think air flow over the resistor cools it.
Prescott
Sep 3, 2007 03:15 PM
Prescott
Jan 21, 2007 11:47 PM
black4x4
9
Jan 11, 2007 01:40 AM
jman1
Oct 28, 2006 10:10 PM
FX4 Matt
Jun 8, 2006 05:55 PM
