OBD Code 1345 Cam/Crank Correlation
Old Apr 21, 2006 | 01:52 PM
iascum's Avatar
Default OBD Code 1345 Cam/Crank Correlation
I am getting a 1345 code which resets 3 seconds afdter I clear it. That is camshaft position sensor/crankshaft position sensor correlation error. Anyone got any ideas at all what could be causing this? Both sensors are new. Is there something I can do to clear it more permenently.
Old Jul 26, 2006 | 12:05 AM
deepz71's Avatar
Default RE: OBD Code 1345 Cam/Crank Correlation
set your crank to tdc should be a indention on the balancer and a mark on the front of the timing cover and then pull the dist. cap and see if if the rotor button is pointing at a little triangular mark. if its not then unbolt the distributor and relocate to the mark, keep in mind the distributor can be a whole tooth off and still run fine, but you will need to take it to a local shop to be dead on the money it only has a tolerence of 2 to -2 degrees of timing. keep in mind the timing is completly computer controlled, there is no adjustment on 96 and newer engines.
gspig01
Jul 11, 2012 03:13 AM
ewayne2
Mar 24, 2011 06:18 PM
vtech1
Nov 1, 2007 10:36 PM
chevypwr01
Jun 30, 2007 04:14 PM
iascum
Apr 20, 2006 02:03 AM
