-   -   Oil change over-fill problem, but not really. (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/oil-change-over-fill-problem-but-not-really-3935/)
RobF1970 Jul 30, 2007 05:26 PM
I have a 1997 K1500 Z-71. 5.7 liter engine. I changed the oil in it and put 5 quarts with new filter like the manual said. Problem is that dipstick shows over-full by close to a quart! I checked part number on the dipstick (10190942) and I think thats the one that is supposed to be on theengine. Yes, I drained all the oil out. My buddy has a 1998 truck like mine. He used the sameoil filter I did, changed his oil (5 qts) anddipstick shows right on the full mark. Whatdo you think the problem could be???
jaxspellinar Jul 30, 2007 05:41 PM
RE: Oil change over-fill problem, but not really.
did you start the truck and run it for a while to fill the filter? It'll take a decent amount on it's own. Any dents in the oil pan from rocks or anything?
RobF1970 Jul 30, 2007 05:48 PM
Yes, I've been driving it now for about 3 days. Oil pan looks fine. Still shows to be over-filled. I know it has to take 5 quarts, but the mystery of the dipstick is killing me. When I bought the truck a couple of weeks ago, it showed overfull then.
gpet6669 Jul 30, 2007 06:00 PM
try your friends dipstick in your truck. then measure the two to see if they get the same results versus there length.
RobF1970 Jul 30, 2007 06:19 PM
Well, I'll try that, but the part number on his dipstick is the same as mine.
gpet6669 Jul 30, 2007 06:21 PM
yeh but the tube could be different!
stopspazinout Jul 30, 2007 07:05 PM
dip sticks probably sitting a little to far into the pan. i know my old 92 chevy with a 305 only took about 4.75 qaurts.
Argon Jul 30, 2007 07:44 PM
at some point,some clown probably put the wrong tube on...or screwed the tube up...
Cracker Jul 30, 2007 09:10 PM
Put an AC Delco P1218 filter instead of the stock. It will provide more filter surface, better flow, and it should be large enough over stock to put the oil at the correct mark. Of course your crankcase may then be 1/2 quart low. or use the above filter and add another 1/2 quart anyway.
72charger Jul 30, 2007 09:14 PM
I would make sure about the dipstick and tube before changing filters. Better to fix the problem then to "rig it".
