-   -   Oil Pressure/Oil Leak (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/oil-pressure-oil-leak-18190/)
acsudberry21 Jan 16, 2012 08:01 PM
I have a 94 z71. My oil pressure is really low and I have noticed that it is also leaking oil around the front of the motor (under the water pump where the oil pump would be). I would assume that these two are related but I just wanted to make sure. If it is the pump how hard is it to replace?
Wiked Jan 16, 2012 09:44 PM
the oil pump was a pain to replace when i did it.
i had to remove the oil pan and all the crap underneath to get to it
acsudberry21 Jan 17, 2012 04:18 PM
what were the symptoms when yours went out? Same as mine? Or did you have any leaks with it at all?
NullHead Jan 17, 2012 11:04 PM
well if it's leaking externally, and from under the water pump, I would think that the issue is the timing chain cover, or oil pan gasket. Maybe crank seal?
acsudberry21 Jan 18, 2012 10:46 AM
Thanks NullHead. Is the timing chain cover a big deal to fix myself? I am moderately handy and im not opposed to tackling it...
