-   -   Oil in radiator (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/oil-radiator-10568/)
cobra139 Jul 6, 2009 07:54 AM
Oil in radiator
Hi, I have a 1998 silverado with a 5.7 vortec engine, 124,000 miles. I recently started to experience a miss while pulling hills at highway speed, I started to look into it today and found I have what appears to be engine oil in my radiator, it's actually a blackish thick fluid when I open the radiator cap, not the milky white that you usually see when water and oil is mixed, would this maybe be a head gasket or intake manifold gasket? Any help please? What checks might I do to find this problem. I have also lost some anti freeze from the holding tank, but do not see any water in the engine oil.
Thanks,
Karl
RUFFNECK4LYFE Jul 6, 2009 09:02 AM
Gotta do a compression check on your cylinders. The one place that is common to have a leak is right above #8. Do that check first.
chrisbmo2000 Jul 6, 2009 11:33 PM
You could also have a leaking oil cooler in the radiator. I would say that is the cause more likely than a cylinder leak is, but do a compression check anyway.
RUFFNECK4LYFE Jul 6, 2009 11:37 PM
Yeah if ur cylinders check ok then check for oil coolant leaks.
cobra139 Jul 10, 2009 04:17 PM
Hi again, thanks for the ideas, I will try to get the time to look into it this weekend. I will let you know what I find.
Karl
cobra139 Nov 8, 2011 12:00 PM
Hi, I havent been back in some time due to a heart attack and open heart surgery, the oil cooler in the radiator was bad, and the miss was from a problem with the vortec heads. I had the heads redone and the problem was solved. Thanks to everyone who answered.
NullHead Nov 8, 2011 11:55 PM
wow good thing you're okay!
Glad you both got all fixed up (you and the truck that is).
