Oil and Trans Fluid cooler
has any one put on a oil or trans fluid cooler? I had a trans fluid cooler on my mustang a while back. and i saw a combo cooler in the latest issue of summit racing. it's 83 bucks and seems like a good idea. any thoughts on gains other than the obvious cooler temps?
RE: Oil and Trans Fluid cooler
any body?
Firmer shifting in cool weather and the tranny fluid will hold up better. The engine oil cooler will take some heat away from the block and prolong the life of your oil.
Oh and when you are towing or in traffic....it is less likely that the transmission will get sloppy.
