option code list
Is there a place either on this site or elsewhere, where I can get a list of option codes for my truck? Found them all in the glove compartment but of course need to find out what they mean.
sorry if I have overlooked the obvious, but i did a search and cannot seem to find them anywhere. If needed the VIN is 1GCEK19T3YZ361197 Cheers!!! |
RE: option code list
here it is...
VIN 1GCEK19T3YZ361197 VEHICLE BUILD Merchandising Model : CK15753-2000SILVERADO LT SHORT BOX 4WD Gross Vehicle Weight Rating : 2906 kg (6408 lb) Order Number : P33076 Build Date : 06/21/2000 Build Plant : 1YZ53 OPTION CODES AG1 - ADJUSTER, 6-WAY POWER SEAT, DRIVER SIDE AG2 - ADJUSTER, 6-WAY POWER SEAT, PASSENGER SIDE AJ1 - DEEP TINTED GLASS AM7 - FOLDING BACK REAR SEAT AN3 - RECLINING FRONT SEATS AU0 - REMOTE KEYLESS ENTRY SYSTEM AU3 - POWER DOOR LOCKS A31 - POWER WINDOWS B30 - FLOOR CARPETING B32 - FRONT FLOOR MATS B33 - REAR FLOOR MATS B71 - WHEEL OPENING MOULDINGS B85 - BELT REVEAL MOULDINGS C49 - REAR WINDOW DEFROSTER C60 - AIR CONDITIONING C7H DF5 DK6 - INTERIOR ROOF CONSOLE DL8 D07 EVA E24 E63 - FLEETSIDE BODY OPTION FE9 FK2 FK3 FLT - FLEET IDENTIFICATION FWI GT5 - 4.10 REAR AXLE RATIO G80 - AXLE - LOCKING DIFFERENTIAL JC5 KNP K05 - HEATER - ENGINE BLOCK K34 - CRUISE CONTROL K47 K68 - 105 AMP DELCOTRON GENERATOR LM7 M30 - 4-SP ELECTRONIC AUTO/OVERDRIVE NF2 - FEDERAL EMISSION SYSTEM NP5 - STEERING WHEEL- LEATHER WRAPPED NP8 NZZ - OFF ROAD SKID PLATE PF9 QBN R7K - MISSING OPTION CREDIT R9Z T96 - FOG LAMPS UP0 - RADIO: AM/FM STEREO, SEEK-SCAN, COMPACT DISC,CASSETTE, CLOCK, UQ3 - PERFORMANCE ENHANCED AUDIO SPEAKER SYSTEM UV8 - CELLULAR PHONE PROVISIONS U19 - KILO SPEEDOMETER VB3 - CHROME REAR STEP BUMPER WITH RUB STRIP VG3 - CHROME FRONT BUMPER WITH RUB STRIP VXS V22 - DELUXE FRONT APPEARANCE V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XBN - LT245/75R16C ON/OFF ROAD S/B RADIAL BLACKWALL TIRES X88 YBN - LT245/75R16C ON/OFF ROAD S/B RADIAL BLACKWALL TIRES YD3 YD6 YE9 ZBN - LT245/75R16C ON/OFF ROAD S/B RADIAL BLACKWALL SPARE ZY2 - TWO-TONE PAINT Z49 - CANADIAN BASE EQUIPMENT Z71 - OFF ROAD CHASSIS EQUIPMENT 1SD - PREFERRED EQUIPMENT GROUP - 1SD 11L 14U - LIGHT GRAY METALLIC 6WY 7WY 92I 922 - SHALE/PEWTER LEATHER |
thats great!!!!thank you very much........whats the trick in getting the codes?
Funny, guy i bought the truck from told me it had 3:73 gears. |
It must have floating axles if its a 410...
how do you tell if has floating axles.
"Floating" axles means...the axle unbolts from the hub..outside..then slides out.A conventional axle has a clip inside the rear end that you remove to slide it out.
.Remove a hubcap and see if there are 8 bolts (3/4)...you remove those 8 bolts and she slides out. Its for strength in heavy pulling. |
