-   -   Painting the Frame (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/painting-frame-12031/)
josh29j Nov 6, 2009 05:06 PM
Painting the Frame
Im painting my frame with Chassis Saver paint. It very similar to POR-15. My question is should i worry about paint over the heads of bolts/threads. I dont want to have problems down the road trying to take them off
shooter313 Nov 7, 2009 09:45 AM
I dont know what POR-15 is, or chassis saver..but if it is not thicker than regular rust preventive paint it shouldn't be a problem for you. I used to paint mine every few years and I never had a problem getting bolts out. You dont want to build up enough on them however that it will change the size socket or wrench that it needs to remove it. If you do then you run the risk of striping the bolt heads down the road on removal.
If it is thick like Line-X for example, then I would avoid anything you are planning on removing during your ownership of the vehicle.
Good luck with your project.
marrymathew Nov 11, 2009 03:40 AM
Yeah you should be very careful with the bolts....Thats really good that you are painting your frame...it seems you are so posessive about it..
Magoo Nov 14, 2009 05:22 PM
If it is similar to POR-15, I'd keep it off from the threads. --
