passenger fender remnoval 98 silverado 1500
Someone backed into my passenger front fender and now I cant open the door. No samage to the door but the fender is now to close to the door and it jams. I am trying to take the fender off but I was wondering which bolts actuallly need to come out to drop the fender.
RE: passenger fender remnoval 98 silverado 1500
take enough off till it falls off...not that many
Thanks I actually went out after posting and put a cumbalong on the fender to pull it from the door so I could open it and got the two bolts in there. Not as bad as I thought it would be, less stuff on the passenger side to take off. I also noticed that the breaks now grab when you first get the truck going and it tends to settle out after awhile. Do you think when they hit the wheel it may have damaged the caliper or could it be something else. I am at a remote lodge with no hex to take it off and test it right now.
There are a lot of items there that could be crushed and causing resistance that feels like the brakes are grabbing. Alignment out, bearings, bent suspention parts.....
