is this the pinion seal?
hey folks
I just replaced the timming cover oil seal the rear man seal and housing seal. also did the steering shaft thing. i was installing neons last night notices a drip where the drive shaft goes into the back of the trans. is that the pinion seal? luck for me i have extended warranty. i only have 48k on it and its an 06 any ideas? thanks Dom |
that the transmission seal
yup. trans tail shaft seal
why are all my seals doing this? its only got 48K on it and its an 06
You said you replaced the rear main seal . well you had to have removed the d-shaft and trans to accomplist that, so it would not be uncommon to create a leak at the slip yoke/output shaft seal upon reassembly.
