RE: Please any help on Posi traction
if your front wheels are spinning faster than the rear wheels, that is not good and you should get that looked at pretty soon.
I tried to check the front tonight. when in the air I could not even budge the driveline. If I turn the tires it does nothing to turn the driveline. Weird. hard to say what is going on. My ahave to breakdown and do it the expensive way
did you make sure it was in neutral? ive done that on my camaro when i lifted the rear to see if it still turned. the wheels wouldnt turn more than an inch and i couldnt figure it out. then i realized it was in park.
yep in nuetral, I did the same thing only in drive but I tried it everywhich way. Defintiley something messed up
Did put the transfer case in nuetral also? or just the tranny.
when you say that you mean actually in 2wd so the front can turn right? so the front transfer is in nuetral? IF so no and now that you say that it makes sense Ill try it again, and again,,,,,, and again
thx for the help |
No I mean actually in nuetral on the tranfer case right off the tranny. You are thinking about the front differential.
