Problem with truck stalling when put in gear
Hey all. New to forum and need help. I have a 91 silverado 350 that when holding brake and put in gear will die. It starts back with no problem. I have changed plugs and wires, egr valve, fuel filter and air filter. Any suggestions would be greatly appreciated.
Thanks for the reply. No its not on. I took it to the shop and the only code that come up was the egr valve is the reason it was replaced. A little more about it it will idle all day no problem. Once it starts driving runs like a champ.
With all the things you have changed I would look for a vacume leak. sounds like thats what it is. The intake is well known for this and coolant leaks also a bad brake booster will do the same thing.
