Racing engine
this is on a 64 chevy after rebuilding the carb the engine just races at startup. ive tried adjusting the idle and messing with the vacuum advance but nothing. any ideas?
RE: Racing engine
What kind of carb/engine are you running?
RE: Racing engine
its not my truck, im just doin the work. buts its a 250 with a 2bbl carb on it and i believe the engine is a 79 if that helps any.
RE: Racing engine
What condition is the linkage in??? You might have a slight problem with the floats sticking or something... Time for a rebuild kit...
RE: Racing engine
this is on a 64 chevy after rebuilding the carb |
RE: Racing engine
YOU must be doin sumthing wrong then, are all the needles and adjustments set correctly?
RE: Racing engine
can the float being bad a possibility here?
RE: Racing engine
I thought you rebuilt it?
RE: Racing engine
yes. rebuilt 2.... exactly the way they came apart but with new parts ive never seen anything like this before after rebuilding a carb. ive done it many times so i dont see how i messed it up unless the float is bad but kits dont come with them anymore these days.
RE: Racing engine
Have you chaecked the timing? Maybe there is a vac. leak...
