Radiator replacement
I found out where i am losing coolant. Is there anyway to weld the radiator to fix it, or am I better off replacing it? Does anyone have any experience with an aftermarket radiator, the gm replacement is $280 and I can get one online shipped to me for $150. Thanks for the advice!
RE: Radiator replacement
Some rads can be welded. It mainly depaends on where it is leaking from. If its comming from a water neck, you can.
you could but your deffinately better off putting a new one in. aftermarkets have the same design to them as an oem one just not made by gm.
if its a plastic tank,your screwed...order 1
Mythbusters put an egg in it to stop it from leaking.
MMMM Eggs |
lol
