rear end ratios for the curious
Old Mar 10, 2009 | 05:21 PM
20''strong's Avatar
Member
Default rear end ratios for the curious
GQ1 -- AXLE REAR, STD RATIO
GT4 -- AXLE REAR, 3.73 RATIO
GT5 -- AXLE REAR, 4.10 RATIO
GU4 -- AXLE REAR, 3.08 RATIO
GU5 -- AXLE REAR, 3.23 RATIO
GU6 -- AXLE REAR, 3.42 RATIO
G80 -- AXLE REAR, LIMITED SLIP (POSITRACTION)
HC4 -- AXLE REAR, 4.56 RATIO
these numbers can be found in your glove box.example:my truck has a gt4 and g80(limited slip 3.73).just thought some of you would want to know this info.
Old Mar 10, 2009 | 09:33 PM
ghlkal's Avatar
Member
Useful info ...
Is there a general listing of the RPO codes on this site?
Old Mar 10, 2009 | 10:01 PM
20''strong's Avatar
Member
http://www.c2e.info/rpocodes/
heres the site for info on all rpo codes for gm(should work for all i think 96 to present)
Old Mar 11, 2009 | 02:31 PM
timber74wolf's Avatar
What is condsidered a "GQ1 -- AXLE REAR, STD RATIO"?
Old Mar 11, 2009 | 03:37 PM
20''strong's Avatar
Member
not positive but i think its open diff.with only passenger tire spins(aka:single tire fire)so if you have gq1 and gu4 that would be 3.08 gear with one wheel spin.
ghostpopi
Apr 30, 2011 09:32 PM
sqdqo
Mar 21, 2009 06:42 PM
stopspazinout
9
Feb 4, 2008 01:15 PM
hrsepwrfrk
Jan 10, 2007 06:52 PM
ReSpAwN DeMoN
Aug 12, 2006 02:31 AM
