rebuilding the dodge killer
Im currently collecting some information as to how much it would cost to rebuild the big block. It was running when the guy pulled it he said that it just started smoking really bad on the one side but it still ran. He figured it was a valve or a hole in the piston. i want to rebuild so that its fairly powerful but yet very strong and reliable. Any information would be appreciated!
What color was the smoke?
White - head gasket. Replace both head gaskets and intake gaskets and change the oil a couple times within the first 1000 miles.
Blue/grey - Oil in the cylinders. If it is only upon start up it's most likely valve guide seals. If it's constant check the compression in each cylinder before you tear it down.
Black - Excess fuel. Possibly a valve. replace plugs and wires and check timing.
jeddhunter
Apr 13, 2008 03:04 AM
JSMConstruction
Aug 14, 2005 02:29 PM
