-   -   Removing Door Panels (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/removing-door-panels-14049/)
GeorgeO8 Jun 27, 2010 09:35 PM
Hello,
Can someone please help with some directions on how to remove door panels off of a 2010 Silverado? I have pulled the door panel out all around the outsite edge...all of the clips popped out easily. The upright door pull had 2 bolts and they were removed. There was also a plastic cover by the door handle that I popped out and removed the bolt that was there as well. It seem as something else is holding it in the middle. I do not see where the interior door handle pops off or detaches. Any help would be appreciated. Looking to do a speaker upgrade.
chevy112488 Jun 27, 2010 10:07 PM
have you pulled upwards? and removed the triangular plastic piece at the front top?
GeorgeO8 Jun 28, 2010 09:21 AM
Yep. Sure did remove the triangular pc. I think I can get it if I can figure out how to remove the interior door handle. Thanks.
RUFFNECK4LYFE Jun 28, 2010 09:49 AM
Right below the armrest of the panel there might b a screw ur missing but not sure.
chevy112488 Jun 28, 2010 06:49 PM
theres a cable running to the interior door handle you have to unhook, much like a throttle cable with the knob on the end. but the door handle itself comes with the panel.
GeorgeO8 Jun 28, 2010 09:18 PM
Thanks for the help.
