no overdrive after filter change
Old 08-07-2011, 09:05 AM
tservice's Avatar
Default no overdrive after filter change
on a 1999 silverado i am getting a trans code of PO753- SHIFT SOLENOID A ELECTRICAL. This occurred right after a filter change. So I am guessing that I had caused a bad connection somewhere. Any idea where to start?
Old 08-07-2011, 03:56 PM
altyson60's Avatar
You are going to have to remove the trans pan and drop the filter again. Maybe when you installed the new filter you might have knocked a wire off one of the shift solinoids.Be careful when working with those, I found them a little fragile. You might want to replace both of them.They are about 20.00$ each.There are installation instructions on you-tube. Just type in '4L60 shift solinoid install'.Its not all that hard.
Old 08-07-2011, 07:44 PM
mcboo_Sierra's Avatar
Member
he's right when you take the pan off, you could have easily unplugged the connection ive seen this before. just plug it back in should be good
cooterlee52
07-01-2010 05:21 PM
cooterlee52
06-28-2010 01:08 PM
dakota03
05-10-2009 04:48 PM
gmc guy2
11-04-2008 09:51 AM
iltfish
10-12-2007 02:26 PM
Quick Reply: no overdrive after filter change
