Rough idle when low on gas
2002 Silverado 5.3 96k
Last week my tank got to about the 1/4-1/8 mark and my truck start to idle rough. I normally dont allow it to get that low so I'm not sure how long I've had this problem. I let it run low again today to see if I had the problem. I do, Almost as if it wants to die. I fill the tank and idles fine. Today I added a bottle of sea foam to my tank. Any Ideas on my problem? |
fuel injector or plugs and wires, but ud think if it was the plugs and wires it would be constant not just low on gas?
Well I am due for a tune up, so that will be my next step.
The fuel pump is not submerged (just the pick-up) when the tank is under 1/4 so you could be getting the pump hotter than normal and the pressure may be dropping. Do a pressure check when it is full and then when it is idling rough and compare the 2 numbers. A tune up should have nothing to do with fuel level.
So I changed all the plugs and wires, noticed I had a cracked coil. Replaced that. Oil change, new filters.
No matter how much gas is in it now I'm still having a rough idle. Sorta like a vibration and a studder every 5 seconds or so. I replaced the plugs with what the prev owner had in it, copper. Ive since found out that the correct plugs are iridium. Could this be the problem? either way should I pony up the money and buy new iridium plugs? |
